Tool Palette Hatching HELP
Hi, I can't work out how to get the tool palette to put down two specific hatching styles that I use regularly.
It seems that I can only use one colour? But if that were the case why on earth does it let me pick another colour in the first place.
please see attached gif as evidence, any help in remedying this would be massively appreciated because opening the hatching command takes time to adjust all the settings (the defaults are presets, and I use user-custom settings.
Pleeeease help as I feel this would be massively useful to myself and my office if I can get the tool palette functioning properly
Many, many thanks
Many, many thanks
Hello,
You can choose the color.
You have to check in Hatch and Gradient dialog box for Pattern > Type > User defined to have set Color > Use current: https://help.bricsys.com/document/_dialogboxes--DB_hatchandgradient/V23/EN_US?id=165079125261
Ah I have found a fix - Turns out for some reason my 'Hatch default color' setting had defaulted back to '4' whereas before it had been '.' which is the 'current colour'.
Many thanks, consider this issue resolved!0
