Code to make a block with the layer as its name.
Hi All, I thought I'd just share this code. I've got over a hundred objects to turn into blocks. I'm organising them by layer so I made this code. I thought I'd post it in case someone finds it useful. Note, you have to keep the drawing open until you've finished or you will get a block name clash because the name number step integer variable will reset to 1.
Here it is
Here it is
(defun c:bb ( / zz aa bb cc ss pp)
(setq zz (entsel)
ss nil
aa (car zz)
bb (entget aa)
cc (cdr (assoc 8 bb))
ss (ssadd (cdr (assoc -1 bb)))
pp (getpoint "\n Select insertion point")
(print "ss =") (print ss)
(if blocknamecounter
(setq blocknamecounter (1+ blocknamecounter))
(setq blocknamecounter 1)
(setq blockname (strcat cc ( itoa blocknamecounter)))
(command "layer" "s" cc "")
(command "block" blockname pp ss "")
(command "insert" blockname pp "1.0" "" "" )
) 0
