CTB set to default
How do I set my custom CTB to the default mode?
  • That can be done in your template drawing that new drawings are created from. Do you know how to edit the template file? A template file is basically a DWG file saved with a different extension. It is good to save your original template file as a back up but then open the file. In the dialog for the Open command there is a "Files of type" option for "Template Format (*.dwt)". Once open use the page PAGESETUP command and set the necessary CBT files. Save the file over the original (again a back up is recommended) or save it as a new file, with the DWT file extension.
  • Options Files Templates, you can set your dwt as the default to be used when starting Bricscad or if you type New.
