Brics equivalent to Acad DWGUNITS?
I've got a dwg made in mm and I want to change it to meters so that when I measure a one meter line it should read 1,000 instead of 1000. In Acad I do this by DWGUNITS and changing index to "6" and then the dwg is reading meters lovely. How can I this with Bricscad? We produce the dwg's originally in an Architectural BIM software (not Autodesk) in mm's.
Cheers,
Mats
