V24 3D Parametric
In the V24 Mechanical Linux version, I'm not able to design with 3D Parametric features. I cannot place any unique constraint. The only possible step is the PARAMETRIZE function, which place all possible constraints. Is there any switch to go back to place unique constraints?
I found when doing constraints that want you to select faces or surfaces, change the SELECTIONMODES variable to 2. See SELECTIONMODES in help section.
Cheers
Dennis
