Textsize civilpoints
How do I change size on the text to civilpoints? When I print drawings the text is to small to read.
  • Click on the "Civil Explorer" in the left side of the ribbon, click on Civil Points > Label Styles > Default, right click and edit as desired.
    I use Bricscad v22, is it the same way to do?
  • I draw elevations using civil points. When I print drawings, the text becomes far too small to be able to read. How do I change this?
