FLATSHOT command problems ?
in 3D Modeling
Trying to create "flatshot" views in perspective mode in V24 fails !
There are also problems displaying a cone roof with the tangent lines (red arrows) ....
Could anyone check if you can reproduce the problems ?
The perspective views (white) are generated in V22 and V23 without problems BUT NOT in V24 ! You find attach the dwg to test
Many thanks !
Many thanks !
I get problems, too. Running v24.1.06 on Windows. My first flatshot attempt created an unrecognizable block of widely diverging lines and splines, some as long as 10^12 m! Then I increased the perspective lens length (to 25 mm from 8.25 mm) and tried again. Flatshot seemed to do nothing that time, until I found the block in structure browser and discovered its UCS elevation to be over 1000 m and its linework scaled very small, on the order of 0.5 m.0
Thanks ! i get exactly the same results... ??? Could be a bug...?0
Same cone roof problem as well for me. May be more than one bug.0
Hi try making your views as "projected drawing views" in paperspace Then use EXPORTLAYOUT.0
