V24 - Screen not refreshing
I'm having an issue with the screen not refreshing after I perform a command - such as erasing some entities. For example, I'll do either an implied window or crossing on the entities and hit the delete key, but the entities don't disappear - until I regen the screen and they are gone. They don't highlight as dashed entities after I've done the window/crossing.
I've tried this in V23 (on the same machine) and it behaves as it should (highlights entities and paints over them after deleting them).
Is there some setting I need to change? As far as I know I have both V23 and V24 configured the same.
Thanks for any help!
