Trouble creating parametric blocks in Bricscad v21
Hi all,
I'm having difficulty creating parametric blocks in BricsCAD v21 compared to v23. While creating the block in v23 is straightforward, when I try to use it in v21 by copying and pasting into my template file, the parametric settings are lost. How can I properly save a parametric block in a template in BricsCAD v21 from v23?
This is what I am aiming for:
This is the result after saving in my v21 template
Final note: I have to work in Bricscad v21 due to some extensions that are valid there.
Thanks
Thanks
You mentioned copy/pasting of block, is there a difference if you insert this block in V21 via INSERT command?0
