OSNAP toolbars
I just installed v3.3.0016 (replacing 3.3.0003) and found my custom OSNAP toolbars no longer work. The standard set work fine. The custom set was set for one time use (so I could get an end point or what ever with out having to turn the snap on then off later). These "one time" buttons have command: _ENDPOINT instead of default command '_ENDPOINT. Why has this stopped working?
Try replacing the commands with their short definitions:_PERPENDICULAR=>_PER_CENTER=>_CEN_ENDPOINT=>_END
I didn't like the fact that the OSNAP's stay activated once you have picked a button. By modifying the standard OSNAP Toolbar I went into my system registery and removed the apostrophe from each OSNAP command. Now, if I choose a command (i.e. Draw Line) and then the OSNAP button, the osnap works as a momentary button. Conversely, If I choose an OSNAP button first and then my Draw Line or any other command such as COPY the OSNAP button I chose stays active and acts as a Running Osnap. When done with that draw set I immediately hit the OSAP CLEAR button to resume working as normal. I have found this to be the best all around solution.RegardsBen Matson
our fault. we reduced the coverage of the snap options too much. We fixed it and it's in the next update.Take snap options 'center'. in practice , 'century' 'centricular' etc was accepted as well, reducing possibilities for other keywords. So we reduced it, but too much. 'CEN', '_CEN' and 'CENTER' work, but _CENTER not anymore. regards, sander, bricscad
Thanks for all the advice. Tryed shortening commands (from _ENDPOINT to _END etc) and now all work as should except NODE (_NOD not responding) but does work as just NODE (not _NODE).RegardsJ Templeton
