Scrip SHADEMODE
Hi, can anybody confirm/help, please?
I want to use SHADEMODE in a Script.
Every time SHADEMODE is executed from the script, I got the wrong command.
it is always -SHADEMODE
so the options are:
Enter option [2d wireframe/3d wireframe/Hidden/Flat/Gouraud/fLat+edges/gOuraud+edges]:
but I want to use SHADEMODE
so the options are:
Enter visual style [2dwireframe/Wireframe/Hidden/Realistic/Conceptual/Shaded/shaded with Edges/shades of Grey/SKetchy/X-ray/Other/cUrrent]: :
in the script there is no difference if I write
SHADEMODE or _SHADEMODE
Is there something I am doing wrong?
Or is it not possible to get the Command SHADEMODE from a script?
so the options are:
so the options are:
Try using the -VISUALSTYLES _C command instead.0
Thank you Owen!Owen Wengerd said:Try using the -VISUALSTYLES _C command instead.
This workaround is working.
