v24 Teething problems....
Having had to wait for Cloudworx to support v24, I have only today installed BricsCAD Pro v24.
Right off the bat, I like to have my panels (Properties, Layers etc.) on the left side and then on the right I have snaps and zoom toolbars.
I've used BricsCAD since v21 and this is the first version I just can't move any of these to where I want them.
I can't move the main bar with Properties etc that is on the right by default.
I have opened snaps which has docked at the top and I can't move it.
I have opened zoom which is just floating in space but i can't move that either.
I am going to assume there's a lock toolbars setting or something which when that is the case is like super simple to find....until now.
......help!
  • ...right holding ctrl and dragging has moved them but they won't dock anywhere now. Why was this so simple I have never had to give it a blind bit of thought before and now someone has decided to make it really annoying, who was this person....why did they do this!?
  • edited December 2023
    My v23 seems to be behaving the same now...what is going on!
  • I have never heard of nor used "LOCKUI" but somehow installing v24 enabled this on it and v23 when it wasn't before !?
    I have now reset to "0" and it behaves as it should again FFS.
  • LOCKUI came some versions before V24 already (V21 ?)
    I am a notorious button/Icon clicker,
    so for me switching means the most right button in the status bar.
    Usually I have LOCKUI enabled. I only switch it off when
    I rearrange Palettes, which I do not do that often.
