Command reference on help.Bricsys.com
We upgraded from BricsCAD Pro to BricsCAD Mechanical this year. Now i wanted to check the command reference list https://help.bricsys.com/en-us/document/command-reference?version=V22&id=165079036112 to check which am* commands are available that can be useful for us. Unfortunately i could only find AMSURFSYM and AMWELDSYM in the list. When i search on the help page there are a lot more AM* commands.
Does anyone now a good ressource for all commands that are available in BricsCAD Mechanical and not in BricsCAD Pro?
Obviously I am asking for a simple solution if there isn't one I will work with the search on the help page.
Kind regards
Michael
