Guide Points
Hi star50,
One way would be to use Infinite Lines, or just polylines and create the guide geometry you need. You can delete it afterwards, or you could place it on a layer that you hide when not needed.
To quickly create an Infinite Line, you can use the shortcut 'XL'.
All the best,
Billie0 -
Hi Billie,
Thanks for that. I had thought of the polylines, however your Layer suggestion gives it better control, and the Infinite Lines I haven't ever used, but can now see a real use for them.0 -
XLs invaluable - use them all the time. Trim the XL's ends away to form the new line you want - or Just delete afterwards - simplest.0
Thanks Tom, I hadn't even thought they were just lines, and you could trim them.0
