Civil Points - How to change the default symbol style and label style?
Hi.
when importing points they come with the default symbol and label style's and I must selcet them all and change both styles to the style that I need.
thanks,
aridzv.
thanks,
aridzv.
Click on the "Civil Explorer" in the left side of the ribbon, click on Civil Points > Label Styles > Default, right click and edit as desired. Repeat for Symbol section.0
@Terry Dotson
So there is no way to set a different styles as the current (default) styles?0 -
Yes, you can. On the appropriate category (like Label Styles) right click and choose Create. Then you can use the PROPS dialog or the CIVILPOINT command, Style option.0
