Possibility to run BETA version next to stable version on one machine?
Hi all,
I was wondering. I would like to contribute to improving BricsCAD and test new beta-versions. However, when I install a beta it overwrites my stable version. When (like the 24.2.01 beta) the beta is unsuitable for production use, I would like to use the stable version instead.
Is it possible, without too much hassle, to install both versions next to eachother?
  • I thought that too in the past.
    But usually the BETA was always as stable as the official version,
    as least as concerning the features of the official version.
    So I always went with the Beta from day one.
    I think that changed a bit with early V24.1 Betas.
    Not exactly what you were asking for.
    One workaround is to keep the previous version.
    E.g. when V24 Beta is unusable, I open my work files in V23
    My second proposal,
    valid for bilingual users only,
    is to install a localized version.
    E.g. I have an international and a german V23 installed.
    This works great as they both use their own user/settings directory.
    And I think you can downgrade the Beta by installing the latest official
    installer. At least after uninstalling the Beta.
    And on Mac you could basically hide/rename/... the Apps to switch between
    them - but they would use the same settings directory, as long as you do not
    manually copy support folders and bending paths in settings.
    I already had an SR about this many years ago.
    AFAIR the official answer was to use a second User Account for your OS.
  • @JorisHoogstede
    Hereby how to run multiple BricsCAD minor/maintenance (e.g.: 24.1 + 24.2 / 24.1.05 + 24.1.06) versions in parallel:
    https://help.bricsys.com/en-us/document/knowledge-base/installation/multiple-installations-of-the-same-bricscad-version?id=165245343862
  • @codrut
    Many thanks!!! I'll have a look into that solution.
