Hello everyone, I created a parameter block and saved it to the tool palette. While applying the block to a new empty drawing, it works; however, in some drawings, the parameters are not functioning as expected.
Parametric blocks can be tricky to set-up to work well in all combinations of parameters that can be changed in any order. Could you post your block here so the forum members can take a look at it?
All the best, Billie
