How to search the object of the region ?
I'm using VBA and I want to search some AcadText object within the specified region.
Is there any method in ThisDrawing.Blocks or AcadBlock or other class or somehow to do so ?
Should I search all of object in 'ThisDrawing' collection with such as "For Each" loop ?
You could use something like this:
Option Explicit Sub Select_Texts() ' Create or set the selection set Dim ssObj As AcadSelectionSet On Error Resume Next Set ssObj = ThisDrawing.SelectionSets.Add("SSTexts") If Err.Number <> 0 Then Set ssObj = ThisDrawing.SelectionSets.Item("SSTexts") End If On Error GoTo 0 ssObj.Clear ' Set the type of window selection and the points that define the region ' for instance p1 = (800,350,0) and p2 =(-20, -10,0) Dim mode As Integer Dim p1(0 To 2) As Double Dim p2(0 To 2) As Double mode = acSelectionSetCrossing p1(0) = 800: p1(1) = 350: p1(2) = 0 p2(0) = -20: p2(1) = -10: p2(2) = 0 ssObj.Select mode, p1, p2 ' Set the filter data Dim gpCode(0) As Integer Dim dataValue(0) As Variant gpCode(0) = 0 dataValue(0) = "Text" Dim groupCode As Variant, dataCode As Variant groupCode = gpCode dataCode = dataValue ssObj.Select mode, p1, p2, groupCode, dataCode MsgBox (ssObj.Count) End Sub0 -
Hello, Virgil.
Thank you for answering.
AcadSelectionSet class and Select method.
I see.0
