Problem with Cloudworx
Just_Me
edited February 2024 in Point Clouds
I have been very happily using Cloudworx in Bricscad for about a year now, but am having a small issue. I have added the Cloudworx toolbar to the edge of my screen, but the icons for changing the point cloud density don't work.
The options are
Point Density Off
Point Density Level 1
Point Density Level 2
Point Density Level 3
Point Density Level 4
When you select them you get this:
: '_cwpointspacing
Unable to recognize command "'_CWPOINTSPACING"
I am using BricsCAD f or Windows x64: 24.01.07 with Cloudworx Basic: 2023.1 Build 1785
System Spec:
M/B: X570
CPU: 5950X
RAM: 128GB (4x32GB 3200)
GPU: 4090FE
O/S: Windows 11 Pro
DISPLAY: 4k / 43"
  • I don't have access to Cloudworx, so I can't perform a test.
    Since there are commands that are not available, this might mean that the plugin is no longer installed correctly.
    The next step could be to uninstall the current version of Cloudworx and perform a new installation.
    In the release notes of Cloudworx Suite 2023.1.0 it is mentioned that the plugin is supported in Bricscad V24, so it should work.
