Express Tools - Mouse Middle Button Overridden
My middle button works for the mouse to have a snaps menu, the moment I set up the Bricsys Express Tools for Bricscad as a menu item, it no longer works. I changed the folder name so it wouldn't load, and now my middle button for my mouse works.
Is there are way to have the Express Tools menu option available and not lose my middle button Snaps Menu?
Try the next steps to add a snap menu to Express Tools menu:
In the Customize dialog (run by CUI command) switch to the Mouse tab -> expand EXPRESS -> Mouse buttons -> Click -> Right click on 'Middle button' -> Insert button -> Check 'Create new tool' -> paste $p0=SNAP $p0=* in the Command field, input a Title, then press OK -> OK to exit the Customize dialog.
