PGP-file stored as TMP
In my support folder I have some "*.tmp-files" which contains the data from a PGP file. I suppose I can delete them - right?
Have a fine day!
Have a fine day!
Your support user folder is typically located at @C:\Users\
\Appdata\Roaming\Bricsys\BricsCAD\...@. You should find your .PGP file there.
Check to see if it has the aliases you are currently using. You can reinitialize the aliases from the .PGP file there with the command REINIT. If they are there and working as expected, then there should be no issue with deleting that .TMP.0 -
Thanks, I removed it.0
