Drawing a BIM Slab using Point Cloud
I'm trying to model a basic 3D model of my point cloud, no building is ever built perfectly square yet it seems like I'm forced to draw the slab as a perfect square.
I use the polysolids to draw the walls at the real world angles but I can't work out the slabs.
hi,
Do you have a BIM license or pro?
In BIM there is the POINTCLOUDFITPLANAR command that will best fit planes to the point cloud. Or you can try the automated tools:
https://help.bricsys.com/en-us/document/bricscad/point-cloud/point-cloud-scan-to-bim-workflow?version=V24&id=169103952811
In pro you can use any traditional modeling tools. e.g. draw a polyline in any shape and extrude it.0
