Issue with HIGHLIGHTEFFECT and HIGHLIGHTCOLOR
Hi team,
A little bit Issue with HIGHLIGHTEFFECT and HIGHLIGHTCOLOR system variables in version 23.2.04., they don't work after changed (see attached pic).
Thanks.
Kind regards
William
Hello William,
For 3D entities like the one from your pictures the settings from the Highlighting section from Settings need to be changed. There you can change the highlighting settings for full or partial entity selection. To do this run the SETTINGS command and in the Search bar look for 'Highlighting'.
The HighlighEffect and HighlightColor system variables control the way 2D entities are selected and highlighted.
Best regards,
Andreea
Thanks.
Kind regards
William
Hello William,
Best regards,
Andreea
There is no picture in your post, so it's not rather clear what's exactly wrong.0
Thank you for your attention!Lyubov_Osina said:There is no picture in your post, so it's not rather clear what's exactly wrong.
I have solved this issue and am just putting the SR history here for others searching.0 -
Thanks! This indeed could be useful for others. Have a good day )
