Parametric block with grip
in 2D Drafting
Is it possible to make parametric block with stretch parameter that has grip (like autocad dynamic block), so you can just stretch it by moving the grip instead of having to type in the length in block properties.
There is no such a possibility in BricsCAD at the moment. Improvement of parametric blocks is an ongoing process, we have a feature request task about parameters edit too.1
In the Bricsys Help Center under "2D parametric blocks" there ist a section "Grip editing a parametric block". Here it is described how to do exactly that. However, it does not work with me. That's why I assume that it still doesn't work, right?
1
