CTRL + TAB Switching direction Windows
I have a problem and I can't find a solution.
The CTRL + TAB keyboard shortcut switches between open windows from right to left.
How to change the switching direction? From left to right?
Usually, by default, CTRL+TAB moves to the next tab from left to right.
For the reverse, CTRL+SHIFT+TAB is used.
In all other programs, e.g. Autocad, web browser, PDF viewer, etc. CTRL+TAB switches windows from left to right.
In Briscad it works in the opposite direction. Is this going to change?
Basically CTLR+TAB = function WNEXT (Windows are switched to in the order that they were created.)
Changing the order of windows manually (by moving) completely ruins the CTRL+TAB function. Switches windows in the order in which files are opened...
I would like CTRL+TAB to work normally like in all other places0 -
Similar changing layouts Ctrl+Pgdn moves up a layout.0
In my testing with V24.1.08 and V23.2.07, CTRL+TAB switched drawing tabs from left to right.
CTRL+SHIFT+TAB switched drawing tabs from right to left.
I couldn't find any specific setting about these shortcuts.
Regarding CTRL+PgUp and CTRL+PgDown, these shortcuts can be found in the cui file.
By default:
CTRL+PgUp is the shortcut for Layout > Previous
CTRL+PgDown is the shortcut for Layout > Next
I have a select current dwg dcl from open dwg's and a Goto layout, goto is missing in CAD, its in Word, rather than have to scroll though tabs list, just goto 12 all done.0
