Code sample for setCoordinateSystem w/ EPSG
Dear all,
I am trying to set a coordinate system via an EPSG code to a file. When browsing the documentation I cannot find any samples or functions to do so. I have spotted
getEpsgCode(int &) const =0 (defined in AcDbGeoCoordinateSystem)
I could not identify any setEpsgCode method. Please kindly assist with a code sample (C# or C++) on how to set EPSG code to a file.
Best regards
Sebastian
  • I found a sample here.
    https://adndevblog.typepad.com/autocad/2016/04/positioning-geographicmarker-using-objectarxx.html
    I have a python wrapper, but it’s not release, it works in AutoCAD, but crashes BricsCAD.
    So I still need to investigate what’s going on
    import traceback
    from pyrx_imp import Rx
    from pyrx_imp import Ge
    from pyrx_imp import Gi
    from pyrx_imp import Gs
    from pyrx_imp import Db
    from pyrx_imp import Ap
    from pyrx_imp import Ed
    #from pyrx_imp import Cv
    # debug
    def PyRxCmd_pydebug() -> None:
    import PyRxDebug
    PyRxDebug.startListener()
    def getGeoDataId(db: Db.Database) -> Db.ObjectId:
    if not Db.Core.hasGeoData(db):
    data = Db.GeoData()
    data.setBlockTableRecordId(db.modelSpaceId())
    return data.postToDb()
    return Db.Core.getGeoDataObjId(db)
    def PyRxCmd_doit() -> None:
    try:
    db = Db.curDb()
    geoCS = Db.GeoCoordinateSystem.create("UTM84-43N")
    xmlStr = geoCS.getXmlRepresentation()
    print(geoCS.getEpsgCode())
    geoDataId = getGeoDataId(db)
    if geoDataId.isNull():
    return
    geoData = Db.GeoData(geoDataId, Db.OpenMode.kForWrite)
    geoData.setCoordinateSystem(xmlStr)
    geoData.setCoordinateType(Db.GeoTypeOfCoordinates.kCoordTypLocal)
    geoData.setHorizontalUnits(Db.kUnitsMillimeters)
    geoData.setVerticalUnits(Db.kUnitsMillimeters)
    geoData.setDesignPoint(Ge.Point3d.kOrigin)
    geoData.setUpDirection(Ge.Vector3d.kZAxis)
    refPtInLatLong = Ge.Point3d(78.384402, 17.434586, 0.0)
    refPtInUTM84 = geoData.transformFromLonLatAlt(refPtInLatLong)
    geoData.setReferencePoint(refPtInUTM84)
    geoData.setNorthDirectionVector(Ge.Vector2d.kYAxis)
    except Exception as err:
    traceback.print_exception(err)
