BricsACD crashes after Block Refedit
When attempting to close the refedit session after editing a block reference the ribbon interface returns to normal but the viewport still appears faded as if still in block edit mode. At this point issuing any further commands fails or even crashes BricsCAD, and the file is unable to save. I'm using BricsCAD 24.1.08, and I'm not sure if the issue is with this version.
Pls is there any fix for it, or is there something I could have tampered with in the settings?
Thanks.
Thanks.
I have very similar problem in the same version (24.1.08). I don't get any precursor for the crash. It only happens when I'm changing the parameters.
It gets worse as I don't get any crash report. I'm working a lot with parametric blocks but the file size is quite small (less than 1 MB).
Maybe Bricscad should look into it?0 -
This is a known problem with REFCLOSE command, development team is working on its correction already. Unfortunaly, there is no workaround for 24.1.08, probably you can temporary downgrade to V24.1.07 till the fix is availible.0
