Infill to Solid
Hi, I am trying to make a copy of a Pier I have seen, just as an exercise.
I am doing this in Shape only as I do not have full BricsCAD.
I need to know how to infill the missing faces and further still, make the whole pier head a tidy solid object.
There is no straightforward way to construct a 3D solid by blending an octagon and a square.
The best approach in this case seems to be to use curves and the LOFT command to construct individual faces.
In the end, after all faces are in place, the DMSTITCH command can be used to create a 3D solid.0
