How to OSNAP only to defined layers?
I know that ...
- there are the settings to ignore OSNAP on PDF, DWF and so
- there is the "cycling selection" and
- Autocad does not have the functionality, but maybe ..
Is there a way in Bricscad to
- OSNAP only to defined elements / layers and/or to
- ignore defined elements / layers in OSNAP?
For example - set layer "Water" to visible and to selectable, but not to be "OSNAPED"?
Thanks for advice?
  • This is not possible out of the box, but it is fairly simple to create a .NET plugin that implements an OsnapOverrule to skip osnap on entities filtered any way you want.
  • Hi Owen
    .NET is beyond my knowledge. Are there ways in Lisp?
    Peter
  • If happy to work with only layers use LAYERISO can have 1 or more layers only selectable, use settings I turn off non selected layers rather than fade.
  • @ALANH
    thanks, but I didn't mentioned it: The layers which I don't want to snap must stay visible - so "layer off" and "layer freeze" are not possible.
  • Layiso is a different command all together its designed to be used as a temporary on/off just try it
    LAYISO LAYUNISO
