V24.2. Triangles in TINS are always shown filled? Can one see just the triangle borders?
Hello
I am trying the just released latest version (v24.2.)
I am working on a TIN. I can't find a way to see just the triangles' lines. Instead of that, the triangles are always filled. In the Properties panel, I can't find a setting to see just the triangles without the fill. Is there somewhere else such a setting?
  • Probably, you need to change the Visual style: when nothing is selected find Visual styles in the Properties panel and set 2dWireframe.
