Automate Entity Conversion: Move Entities to Layer Zero Maintain Original Properties
Goal:
Find methods to help assemble a new LISP program or find an existing LISP program to perform the following:
Convert all entities to layer zero while maintaining properties as originally assigned based on the entities' original layer.
Details:
In a single DWG file, 700+/- details are organized and include drawing borders that supply individual details to our main non-Autodesk specialized and multi-functional design application.
Please provide:
- Links to and/or actual LISP programs that perform this or similar conversions.
- LISP tips and/or instruction on links to methods to create a conversion LISP program.
- Non-programmed methods to accomplish this conversion.
(Almost a)
I do something like that, using the two custom commands in the attached lisp file. In files that I get from other people, I use the those commands to eliminate all Bylayer color and linetype, giving each entity the color and linetype it would have on its current layer. Then I can move them to any layer without losing their color and linetype. I don't move all entities to layer 0, but that's easy to do using the Entity Properties pull-down list (if that still exists in v24).
In drawings I get from other people, lineweight is usually Bylayer for all entities, but the layer lineweight for all layers is usually Default; so that's no help. But I have a custom command that selects all entities of a particular color, and for each of colors 1 to 7 a custom command that selects all entities of that color, plus a custom command that gives those entities the lineweight that's associated with that color in my CTB file.0 -
And the two custom commands in this lisp file do the same thing but for the entire DWG file, not just for the selection set.0
These are great programs, Anthony!
Thanks,
Clint0
