Create custom visual style or composition by BIM model pset
mvicenzi_83
edited March 2024 in BricsCAD BIM
HI,
is it possible to create a custom visual style for 3d modeling using one property sets in a BIM model?
  • Hi,
    not with the native commands but by scripting this should be possible.
  • Hello Piet,
    it's nice to hear from you again. Do you mean a Python script to use in the BIM environment?
  • Setting a visual style with Python will not be possible, Python only works with BIM properties. With Lisp you probably could but I never tried before.
  • Do you want entities to have different representation depending on their BIM properties?
    Have you checked GRAPHICOVERRIDE ?
  • Thank you so much Ruben,
    I didn't know about the function! It's a shame that it's not possible to apply a stratigraphy in a way that allows for multiple overlays simultaneously.
  • Hi,
    That would indeed be a nice addition! It's on our list of future ideas, I added an upvote.
  • Hi Ruben, I'm sharing this "solution" with you just out of curiosity.
    At the moment, I've worked around it by using a combination of graphic overrides and BIM filters on the PSETs to perform the checks I need.
