Ellipsoid arc lengthening
in 2D Drafting
Why there is no possibility to use lengthen command to ellipsoid arc. Sometimes it is necessary.
You are right, LENGTHEN command doesn't work on ellipsoid arcs, but it's possible to edit them via Properties Panel.0
