Polylines: how to select and move multiple vertices?
Moving a single polyline vertex can be done simply by clicking on the vertex and dragging it. However, there doesn't appear to be any way to select multiple vertices and then moving them together.
This is surprising, given that it is one of the most basic, intuitive concepts that is used when editing polylines (for example: editing paths in Inkscape).
I have tried searching the documentation for this, but have not found anything that indicates how to select and move multiple polyline vertices. Is this possible in Bricscad, or is the software missing a feature that all polyline editors should have?
