Button Macro Insights Needed
GOAL: Create a button macro to load the DASHED linetype to the active file.
Button macro insights on limitations and assistance in correcting the code below is appreciated.
^C^C-LINETYPE;L;DASHED;
ISSUE 1: The macro stalls at LIN file selection dialog box (the current selection is and is desired to be the DEFAULT.LIN file.)
ISSUE 2: If the DASHED linetype is already loaded, is there a method to code the button macro so it does not stall at the RELOAD Y/N prompt?
Thanks,
Clint
Thanks,
Clint
Google "load linetype Autocad lisp" you will find so many examples.
a hint (tblsearch "Ltype" "dashed")0 -
You can use the EXPERT sysvar to turn off prompting if the linetype already exists.
e.g.^C^CEXPERT;3;-LINETYPE;L;DASHED;EXPERT;0;0
