Can be crosshair size be more than 100?
1. Print Setting > Only PDF Locked Option
2. Croshair Size is also not goes over 100
Our customer is facing these issues on MAC issues
Mac Version is Sonoma 14.4.1
Bricscad version is: V230 -
This is a known issue that CURSORSIZE >10 doesn't work on Mac, if CROSSHAIRDRAWMODE has some value exept 3. It's nesessary to set CROSSHAIRDRAWMODE=3 to resolve this.0
I think I don't really understand.
AFAIK crosshair size is in percent.
So 100% is full screen cursor.
In the past that did not work on Mac though.
If you set crosshair size larger than 14 % (?) the crosshair just
disappeared. That was fixed lately. But I think that was with V24.0 -
As I know, if CROSSHAIRDRAWMODE=0 and CURSORSIZE >10, crosshair size remains at the same size as CURSORSIZE=10. If CROSSHAIRDRAWMODE=1 - the cursor disappears. Also 2D Graphic System Device RedOpenGL or OpenGL could have different effect. But it must work as expected if CROSSHAIRDRAWMODE=3.0
