Solid extrusion strange behaviour
in 3D Modeling
Extruding of planar object in WCS, normally accepting default solid depth works fine. Unfortunately in UCS, when I accept default depth value, result is accidental, unless I type extrusion value manually.
Hello.
There is an issue when using EXTRUDE with a coordinate system other than WCS.
This is currently being investigated.
A side effect is the behavior reported here.
For now, with a custom UCS, the solution is type in the value each time.
If possible, several entities could be selected and extruded at once.
