Sample lines
Hello. I'm testing Brics Bim vs C3D. Given that I mostly use C3D to draw longitudinal and cross-sections of the terrain, I would like to know if a similar way of working with Brics is possible?
In C3D, you create an alignment and then attach sample lines to it.
From these sample lines, you can create cross-sections and you can project various elements into them. Is something like this possible in Bricscad BIM?
  • Hello.
    The sample lines feature is not implemented in Bricscad Civil.
    For now, to analyze the corridor, it needs to be extracted as a 3D solid or mesh.
    Then the sections need to be added manually and the views created as layout viewports.
    Most likely, a better approach would be to use a third-party plugin, like Civil Site Design.
