Incomplete AcString helper functions?
Been trying to use some function from AcString class.
This one for example,
AcDbHandle asAcDbHandle (int=kParseDefault) const
VS is refusing to compile, and showing this linker error. although I can use other functions from the same class and compile without problems.
error LNK2019: unresolved external symbol "__declspec(dllimport) public: class AcDbHandle __cdecl AcString::asAcDbHandle(int)const " (__imp_?asAcDbHandle@AcString@@QEBA?AVAcDbHandle@@H@Z) referenced in function "protected: int __cdecl
I tried referencing all libraries from the sdk and I including all possible header files.
Have anyone encountered this before?
BRX is a bit behind. You will need to report the missing function(s) as a support request
Then find a work-around
AcDbHandle(const ACHAR*)
bool getIntoAsciiBuffer(ACHAR* pBuf, size_t nBufLen) const;// enum {kStrSiz = 17};1
