Needed - Simpler AWI Welding Symbol LISP
Can someone recommend a non-commerical LISP routine or or affordable commercial application that inserts various welding symbols in inch/imperial units?
What is hard about inserting blocks ? You have various ways you can select which weld type, name, dcl, pop menu etc.
Post a dwg with typical symbols.
This is a pop menu with select from image.
Have a look at
Have another idea based on AWS weld chart waithing for you.
BricsCAD Mechanical includes the AMWELDSYM command for placing weld annotation symbols.
