Select command: Where is the select window "panel"
There used to be a select windows that opened when the Select command run. In v24 I can't find it.
Is it gone? Can it be activated somehow?
The commands that are included in it can be accessed as Selection Options (type "?"), but that window was more useful. The options could be placed in modern "Command Context" panel, but they are not currently.
I think it's settings→prompt menu. or promptmenu sysvar
2 -
Thank you
-1
