New PropertySet not showing its label (BIMPROPERTIES)
I`ve made a PropertySet that is applied for certain classified objects, the "New PropertySet" is labeled "TEXT" and also shows up as "TEXT" as the headline in the properties panel when selecting the object.
But when exporting as IFC and opening the IFC in a viewer(Dalux in this case), this section of information still uses "New PropertySet" as a headline instead of "TEXT", why is this happening?
I cant change the PropertySet ID inside BIMPROPERTIES.
Is it an IFC issue? Or just me not understanding how the naming works?
Hello.
The IFC format seems to use a single attribute related to naming a property set.
This attribute is the ID.A quick fix could be to edit the .ifc file and replace "New PropertySet" with "TEXT".
Then, import the .ifc file into Dialux.0 -
Thanks for the reply.
How do you suggest I edit the .ifc? Is there a tool for this?
Hello.
The .ifc file can be edited with a text editor, Notepad for instance.
Worked like a charm :) Thanks for the tip!
