MTEXT formatting toolbar disabled
Hi, I'm quite new to BricksCAD but have used AutoCAD earlier.
I have a problem when I'm trying to edit Mtexts. If I enable MTEXT Formatting toolbar in SETTINGS, I get: "Error occurred in mtext editor: Invalid index" when I try to edit a text. If I try to insert a new MTEXT I'm asked to specify the box, but then I get:
Create failed". I have no MTEXT editor specified.
If I disable the formatting toolbar in SETTINGS everything works OK. No toolbar though…
IT department have no clue, as usual with the technical software
Now I'm using V24, but earlier I had V23 (or V22, or V21) with the same problem.
Any suggestions?
Hello.
The issue can't be reproduced from scratch with any of the V21, V22, V23, and V24 versions.
Something that could be useful is a clean install.
Invalid Index indicates an issue with the MTEXT entity(s) on your drawing. I would try doing an AUDIT or RECOVER on the drawing to see if it resolves the issue.
If this doesn't work, then I recommend that you raise a support request and attach the drawing so that Bricsys can investigate.
