Object not selectable in active story.
When a story is active, in this case "Plan 01" at level 0: When I draw something or insert something, it imidiately gets greyed out and cant be selected, even if its height is 0, the same as the story.
How can I prevent this? Is there some threshold I can adjust?
At the story-bar its adjusted to show a little from above and below the story level.
In the attached image, I drew the polyline zigzag, but it got greyed out once the command had finished. I`ve had this happen to inserted objects as well.
Hello.
This issue has been reported and it is under investigation.
It occurs with 2D entities after adjusting the sliders - the entities become locked.
For now, if editing the sliders can't be avoided, when the locking occurs, something useful might be to select the entities outside TVM (Top View Mode), cut them (CTRL-X), enter TVM, and paste them back.
However, aside from the extra-work, another draw-back with CUTCLIP - PASTECLIP is that it is not possible to keep the position, so, this approach has only a limited use.
