Cutting a hole, then move it around
When drawing in cable-trays, I sometimes need to make holes in the walls for the tray to go through, later the customer may want to move the tray, so I guess doing the hole with boolean operations is not the best way.
Can I make a 3D solid with som kind of cutting object that makes the hole and can be moved around on the fly? Similar to a "opening cut" in Revit or a wipeout when 2D drafting?
