Lisp dont work in Briscad
edited May 2024 in LISP
Hello.
I have a lisp that defines a set of commands which enable the user to populate a selected annotation object (Text, MText, Attribute) with a field expression referencing the name and position of the layout in which the object resides.
Works perfectly in AutoCAD, but in Bricscad it does not work, it makes the field formula but does not give the result of the layout number or the total number of layouts.
;; Layout Name ;;
;; Generates a field expression referencing the name of the layout ;;
;; in which the selected annotation object resides. ;;
(defun c:lfname ( )
(layoutfield
'(lambda ( obj )
(vla-put-textstring obj
(strcat
"%<\\AcObjProp Object(%<\\_ObjId "
(LM:objectid (layoutfield:layout obj))
">%).Name>%"
;; Layout Number ;;
;; Generates a field expression referencing the position of the layout ;;
(defun c:lfnumber ( )
(layoutfield
'(lambda ( obj )
(strcat
">%).TabOrder>%"
;; Sheet Number & Total Sheets ;;
;; in which the selected annotation object resides, and the total ;;
;; number of paperspace layouts in the drawing. ;;
(defun c:lfsheet ( )
(layoutfield
'(lambda ( obj )
(strcat
"%<\\AcExpr %<\\AcObjProp Object(%<\\_ObjId "
(LM:objectid (vla-get-layouts (LM:acdoc)))
">%).Count>%-1 >%"
(defun layoutfield ( fld / *error* ent )
(defun *error* ( msg )
(LM:endundo (LM:acdoc))
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(princ)
(while
(progn (setvar 'errno 0) (setq ent (nentsel "\nSelect text or attribute: "))
(cond
( (= 7 (getvar 'errno))
(princ "\nMissed, try again.")
( (null ent) nil)
( (or (< 2 (length ent))
(not (wcmatch (cdr (assoc 0 (entget (setq ent (car ent))))) "TEXT,MTEXT,ATTRIB"))
(princ "\nInvalid object selected.")
(if ent
(progn
(LM:startundo (LM:acdoc))
(apply fld (list (vlax-ename->vla-object ent)))
(if (= "ATTRIB" (cdr (assoc 0 (entget ent))))
(vla-regen (LM:acdoc) acactiveviewport)
(princ)
(defun layoutfield:layout ( obj )
(if (and (vlax-property-available-p obj 'islayout) (= :vlax-true (vla-get-islayout obj)))
(vla-get-layout obj)
(layoutfield:layout (LM:owner obj))
;; Owner - Lee Mac
;; A wrapper for the objectidtoobject method & ownerid property to enable
;; compatibility with 32-bit & 64-bit systems
(defun LM:owner ( obj )
(eval
(list 'defun 'LM:owner '( obj )
(if (vlax-method-applicable-p obj 'ownerid32)
(list 'vla-objectidtoobject32 (LM:acdoc) '(vla-get-ownerid32 obj))
(list 'vla-objectidtoobject (LM:acdoc) '(vla-get-ownerid obj))
(LM:owner obj)
;; ObjectID - Lee Mac
;; Returns a string containing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:objectid ( obj )
(eval
(list 'defun 'LM:objectid '( obj )
(if (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
(list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
'(itoa (vla-get-objectid obj))
(LM:objectid obj)
;; Start Undo - Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
(LM:endundo doc)
(vla-startundomark doc)
;; End Undo - Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
(while (= 8 (logand 8 (getvar 'undoctl)))
(vla-endundomark doc)
;; Active Document - Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
(eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(LM:acdoc)
(vl-load-com) (princ)
Right now I am using Bricscad in Spanish
  • Hello.
    There is an issue with using the (getobjectidstring) function in Bricscad.
    The issue is currently being investigated.
    For now, temporarily, the (LM:objectid) function could be adjusted like this:
    <pre>
    (eval
    (if (= "BRICSCAD" (getvar 'program))
    (LM:objectid obj)
    </pre>
  • it gives me this error
    ; error : malformed list on input at [read] : File <C:/Users/xxxx/Downloads/NUMER LAYOUT.LSP>
  • Hello.
    Apparently, the issue occurs with a call of the (read) function.
    The code here doesn't contain such a call and seems to have the correct syntax.
