difference with some colors between Bricscad and Autocad
I have seen that there is a difference with some colors between Bricscad and Autocad.
in autocad color 252 is RGB 102,102,102
In Bricscad the 252 is RGB 132,132,132.
Does anyone know why?
Can be modified?
This depends on background color. If you set the same display background color, e.g. Black, in both programs, RGB values of Index colors are the same in BricsCAD and AutoCAD.
1 -
ok
Thank you
