FIND command : zoom settings
is there a setting or toggle to disable the full screen zoom to text when using find? or at least have a zoom previous when the command is done. v24.2.05
  • There is no such an option, but you can try to restrict area of search - select some part of the drawing before running FIND command and process search with option "Current selection".
