How-to / Tips Needed: Custom Library Setup and Distribution
Web resources appear to be minimal on the topic of BricsCAD library customization as far as exporting/transferring them as part of a comprehensive set of CAD standards.
Your input on the above topic is appreciated and needed!
Thanks,
Clint
UPDATE
I located the default library resource files path and directory paths.C:\Program Files\Bricsys\BricsCAD V24 en_US\UserDataCache\Support\en_US
C:\ProgramData\Bricsys\Components\
My plan is to create custom libraries under the local drive under a main folder, C:\BricsCAD.
In settings, do I need to relocate (or, add a new path to,) the default folders located under the Library Directory Path - COMPONENTSPATH ?Thanks,
Clint
Our custom libraries were saved to a server and read from there. I found it easier to maintain yes had multiple users, we had custom menu's driving it all. We just added correct support paths.
For a recent client did an Install.lsp this sets paths, loads menu's etc an important part it unzips a zip 37Mb to a newly made directory on the pc as no server. User is then ready to go. Happy to describe more.
1 -
Ideally, you would use AppData\Roaming\Bricsys\BricsCAD\...
C:\, C:\Program Files\ may require elevated rights
My thanks to both of you.
Dear ALANH,Boy, would I like to find out more about this setup!For some background on my current scenario, my company is totally cloud-based, my setup and customization experience has not included shared customization nor multiple user support.I am open to learning how best to make available company CAD customization.P.S.: It is too bad that I cannot get forum messaging to work on my end. Can you?Regards,
Clint
