Transparency not showing
Hi there, I've attached an image and put the Transparency on 50. I use BricsCAD V22 (Macbook) at home and BricsCAD V21 en V22 (windows) at the office. The DWG shows the Transparency right at the office, but at home, I doesn't show the Transparancy.
Variable TRANSPARENCYDISPLAY is set to 1
When I print the drawing, the transparency is working just fine.
Is this a Windows vs Macbook issue?
(I tried it also with a PNG, but that doesn't show transparency either)
